Programmatically Capture Image from TDS2024C
IceCream
Post by IceCream » December 18th, 2018, 6:26 am
I use following commands to capture image from TDS2024C:
SAVE:IMAGE:FILEFORMAT BMP
SAVE:IMAGE A:\waveform.bmp
However setting these commands does not do anything. I am confused, because the oscilloscope has Save/Recall button and it works fine.
Re: Programmatically Capture Image from TDS2024C
Post by David N » December 20th, 2018, 11:43 am
Please refer to the programming examples on the forum at: viewtopic.php?f=580&t=133570
IceCream
Post by IceCream » December 28th, 2018, 7:20 am
Great! The answer is here: viewtopic.php?t=139957.
Users browsing this forum: No registered users and 8 guests
