Needed NVSRAM Dump of TDS640 or/and TDS600 field adjust software
Madao123
Post by Madao123 » November 6th, 2019, 9:03 am
Hello people.
I have reparied TDS640,of course capacitor plague.
But NVSRAM is corrupt und i am needed dump of functional TDS640.
Do exist TDS600 field adjust software?
Thanks.
Matt
Madao123
Re: Needed NVSRAM Dump of TDS640 or/and TDS600 field adjust software
Post by Madao123 » November 8th, 2019, 10:34 pm
I got NVSRAM Dump.
I am again needing field adjust software.
Regrads
matt
fenugrec
Country: Canada
Post by fenugrec » November 18th, 2019, 10:49 am
google gives
https://www.eevblog.com/forum/testgear/ ... #msg539818
which has links for different versions which may need to be tested.
Madao123
Post by Madao123 » November 24th, 2019, 5:01 am
Solved, i got modified FAS .
fenugrec
Country: Canada
Post by fenugrec » January 29th, 2020, 3:17 pm
Excellent.
What do you mean by "modified FAS" ?
Madao123
Post by Madao123 » February 25th, 2020, 9:45 am
Mofication of Tek FAS ist minor, from eevblog
Attached below is TDS600A.ADJ Field Adjustment Software. To add support for TDS640 (plain, no letter) to TDS600A.ADJ after installation:
Open directory TDS600A.ADJ
Edit DUTLIST. There are three entries, TDS620A, TDS640A and TDS644A
Add TDS640 below the last entry, save and close file DUTLIST.
It is necessary to make a copy of file Tds640a.con, and name the copy Tds640.con
Also, make a copy of file Tds640a.idx, and name the copy Tds640.idx
It is not necessary to edit either file copy. With these steps, I have successfully calibrated a TDS640 on the first attempt.
Greeting
matt
