Phase measurement TDS2024C
felixpradoh
Country: Finland
Post by felixpradoh » April 26th, 2020, 10:58 pm
I am trying to get the phase between two sinusoidal waves in a TDS2024C scope by python and pyVISA.
Nevertheless, I couldnt find this command in the Programming Manual. Just manually from tthe front pannel. Does anyone know if it is possible, or someone did it?
Thank you.
w2aew
Re: Phase measurement TDS2024C
Post by w2aew » April 27th, 2020, 6:05 am
This can be done. The MEASUrement:IMMed:TYPe PHAse command is available and documented in the programmers manual.
felixpradoh
Country: Finland
Post by felixpradoh » April 27th, 2020, 7:43 am
Thanks for your fast answer.
Following the next command (I am using a small python script with pyVISA), I am able to set the Measurement 1 as a Phase type. This works with:
'MEASUrement:IMMed:TYPe PHAse'
However I would like to set that the source1 and source 2 are CH4 and MATH, respectively. I have tried:
'MEASUrement:INMed:SOURCE1 CH4'
'MEASUrement:INMed:SOURCE2 MATH'
but unfortunately the sources don´t change in the scope.
w2aew
Post by w2aew » April 27th, 2020, 7:51 am
Looks like you have a spelling error.
Should be:
'MEASUrement:IMMed:SOURCE1 CH4'
'MEASUrement:IMMed:SOURCE2 MATH'
