keithley 6845 labview
sberam
Country: Canada
Post by sberam » June 29th, 2020, 10:29 am
I am using the keithley 6485 driver on labview. I am having a hard time keeping zero check and zero correct on. Here is the code I am using. I turn zero check on but it turns off as soon as measurements are triggered. I am having a similar problem with zero correct. Ideally, I want to turn on zero check, turn on zero correct, and then turn off zero check before measuring the current.
