Capture waveform screenshot from MDO3014 oscilloscope
venu13
Post by venu13 » September 17th, 2020, 6:35 am
HI, I am using TekVisa library to communicate with MDO3014 oscilloscope through USB in C#.
I am trying to save screenshot of oscilloscope and write it to image file but the image file is corrupted.
//Code snippet
tekVISA.Write("SAVe:IMAGE FILEF BMP");
tekVISA.Write("HARDCOPY START");
bool status3 = tekVISA.Read(out response);
Console.WriteLine(status3);
string filepath = @"C:\Temp\test.bmp";
using (BinaryWriter binWriter =
new BinaryWriter(File.Open(filepath, FileMode.Create)))
binWriter.Write(response);
Please let me know what mistake I am doing here.
w2aew
Re: Capture waveform screenshot from MDO3014 oscilloscope
Post by w2aew » September 17th, 2020, 6:52 am
What version of firmware are you running? There was an issue with support of the HARDCOPY START command that was addressed in the later firmware versions.
The most recent firmware is v1.30, and can be found here:
https://www.tek.com/oscilloscope/mdo301 ... lease-v130
venu13
Post by venu13 » September 17th, 2020, 6:56 am
I am using latest firmware version - v 1.3
Carl M
Post by Carl M » September 17th, 2020, 7:27 am
How many bytes are in response? I would check to make sure you've read all the bytes.
Dave W
Post by Dave W » September 17th, 2020, 8:31 am
Hi venu13. It looks like you are using the TekVISANET library. You are using the incorrect read method from that library. The one you are using outputs the data as a string. You need to use the ReadBinary() method which outputs the data to an array of bytes (byte[]). Strings in C# are not the same as C/C++ strings and reading to those will cause corruption of the binary data returned from hardcopy.
venu13
Post by venu13 » September 18th, 2020, 1:56 am
I tried with ReadBinary method, but not getting any data into byte array from HARDCOPY START command. It is empty.
byte[] waveformResponse;
bool status3 = tekVISA.ReadBinary(out waveformResponse);
Here status3 is False, and waveformResponse is empty.
Dave W
Post by Dave W » September 18th, 2020, 1:48 pm
Looking at your code there looks like a command syntax error in the second line.
should read
tekVISA.Write("SAVe:IMAGE:FILEF BMP");
If that command is not set correctly, the scope could be in a state where it doesn't know the desired format of hardcopy and so it doesn't return anything.
Note: You can check that you haven't sent any bad commands by sending the command *ESR? followed by ALLEV? If *ESR? returns anything other than 0 then there is an event (or error) the scope has in its event queue and ALLEV? will read back the queue.
