python 3 afg3k afg2k send wfm
Carl M
Post by Carl M » January 27th, 2017, 4:54 pm
a port of the MATLAB example AFG3000 MATLAB ICT Send Waveform 1: viewtopic.php?f=569&t=133567#p282128
should work in python 2 as well
# afg3k_send_wfm_1.py
# date: 01-27-2017
# demonstrate 'data:define' and 'data' remote programmatic commands for the
# AFG3000 series and AFG2000 series.
# The data following the binary block header is unsigned 16-bit integer
# values, most significant byte first (big-endian). Bits 15 and 16 are
# ignored as the AFG has 14-bits of dynamic range. The key concept is the
# digital values are unit-less. Value 0 is the minimum output and value 16382
# is the maximum output. Amplitude (and offset, and timing) are applied at
# run-time based on the AFG settings.
# Python v3.6.0 32-bit
# numpy v1.12.0
# pyvisa v1.8
# NI-VISA v15.5
# AFG2021 v1.1.9
# Tektronix provides the following example "AS IS" without any guarantees
# or support.  This example is for instructional guidance only.
import numpy as np # http://www.numpy.org/
import visa # https://pyvisa.readthedocs.io/en/stable/
# variables
visa_descriptor = 'tcpip::134.62.36.59::instr'
record_length = 12
# calculations
# example arbitrary function: 1-cycle sine
sample = np.arange(record_length)
vector = np.sin(2 * np.pi * sample / len(sample))
# normalize to dac values
m = 16382 / (vector.max() - vector.min())
b = -m * vector.min()
dac_values = (m * vector + b)
np.around(dac_values, out=dac_values)
dac_values = dac_values.astype(np.uint16)
print('digital sample values...')
for i in dac_values:
    print(' 0x{:04x}'.format(i))
# instrument communication
rm = visa.ResourceManager()
afg = rm.open_resource(visa_descriptor)
afg.write_termination = None
afg.read_termination = '\n'
afg.timeout = 10000 # ms
r = afg.query('*idn?')
print('connected to...\n{}'.format(r))
print('clearing event status register & flushing messages')
afg.write('*cls')
r = afg.query('*esr?')
print(' esr value: 0b{:08b}'.format(int(r)))
r = afg.query('system:error?')
print(' msg: {}'.format(r))
cmd = 'data:define EMEM,{:d}'.format(record_length)
print('writing: "{}"'.format(cmd))
afg.write(cmd)
afg.write_binary_values('data EMEM,',
                        dac_values,
                        datatype='h',
                        is_big_endian=True)
print('disconnecting...')
afg.close()
print('done')
shell output
 0x1fff
 0x2ffe
 0x3bb5
 0x3ffe
 0x3bb5
 0x2ffe
 0x1fff
 0x1000
 0x0449
 0x0000
 0x0449
 0x0fff
connected to...
TEKTRONIX,AFG2021,C010334,SCPI:99.0 FV:1.1.9
 esr value: 0b00000000
 msg: 0,"No error"
writing: "data:define EMEM,12"
 msg: 0,"No error"
 msg: 0,"No error"
disconnecting...
done
NI IO Trace and AFG2021 display verification
