modifying Python: TBS Simple Plot
kvarun95
Post by kvarun95 » July 26th, 2017, 2:59 am
Is it possible to use this for dual channel? I guess the command
scope.write('data:source CH1') # channel
would need to be edited appropriately?
Carl M
Re: modifying Python: TBS Simple Plot
Post by Carl M » July 31st, 2017, 12:48 pm
code examples are intended to demonstrate. if you wish to modify but have questions, please start a new topic and be specific.
Default setup and auto-set are compromises for convenience.
adding a second channel is beyond scope of the example but the example does provide a place to start.
changing the source is only a part of it. you need to setup the acquisition and acquire data before the sample vector will be available.
