Incomplete Hardcopy Retrieved from TBS 1052B-EDU
ChrisTheBaron
Country: United Kingdom
Post by ChrisTheBaron » February 22nd, 2018, 6:04 am
Using C# and code adapted from viewtopic.php?f=580&t=139957, the response I'm getting back is an incomplete screenshot (See tmp.bmp). I have included
C:\Windows\assembly\GAC_32\TekVISANet\1.1.1.0__7f19bb2a5a9ae6e8\TekVISANet.dll
in my Visual Studio project.
// connection code omitted.
TVA.Timeout = 50000;
TVA.Write("HARDCopy:FORMat BMP");
TVA.Write("HARDCopy:LAYout PORTRAIT");
TVA.Write("HARDCopy:INKSaver ON");
TVA.Write("HARDCopy:port USB");
TVA.Write("HARDCopy START");
TVA.Read(out string temp);
using (FileStream fs = new FileStream(@"C:\tmp\tmp.bmp", FileMode.CreateNew))
using (BinaryWriter sw = new BinaryWriter(fs))
	sw.Write(Encoding.ASCII.GetBytes(temp));
Example hardcopy.
Carl M
Re: Incomplete Hardcopy Retrieved from TBS 1052B-EDU
Post by Carl M » February 26th, 2018, 3:20 pm
the bytes of the file that comprise the screen capture in BMP format are likely getting terminated early because of a linefeed character. This typically happens when you perform ASCII operations on binary data. You could confirm this with a VISA trace. IIRC, your TVA object has a ReadToFile() method that would be better suited for this task. The example you reference is using the NI VISA library, not the TekVISA ActiveX control. The commands the the instrument are otherwise correct.
ChrisTheBaron
Post by ChrisTheBaron » March 8th, 2018, 6:04 am
Thank you for replying so promtly.
I have looked, and I cannot find a ReadToFile() method on the TVA object. I have tried ReadBinary() but I get 0 bytes returned. I have also tried a few other string encoders (Unicode, UTF7, UTF8, UTF32, BigEndianUnicode) but none seem to work. Setting the format to JPEG creates an entirely invalid file. For reference I have attached the output if I set the layout to landscape.
I cannot install the NI Visa library as I am developing on a university machine and I do not have admin rights.
Landscape
