Python Make WFMX (ElementTree API)
Carl M
Post by Carl M » June 11th, 2018, 4:31 pm
This is a proof-of-concept example for user created WFMX files. WFMX is the native waveform container for the Tektronix AWG70000 and AWG5200 series arbitrary waveform generators and SourceXpress arbitrary waveform generator software. The Tektronix WFMX structure is extensible but not complex. It starts with an XML header followed by binary data. Python has many built-in tools for XML processing: https://docs.python.org/3/library/xml.html This example demonstrates of the ElementTree API to create a functional WFMX XML header. Numpy is used for creation of simplistic example vectors.
Related: Python Make SEQX (ElementTree API)
# demo: creating WFMX files
# for Tektronix AWG70000 and AWG5200 series
# and SourceXpress software
# WFMX structure
# XML header (required)
# single precision vector 1 (required)
# single precision vector 2 (optional)
# unsigned 8-bit integer marker vector (optional)
# marker encoding
# marker 1 = bit 0
# marker 2 = bit 1
# marker 3 = bit 2
# marker 4 = bit 3
import xml.etree.ElementTree as ET
import datetime
import numpy as np # http://www.numpy.org/
# example vectors
idle_wfm = np.zeros(2400, dtype=np.single)
s = np.arange(5000, dtype=np.single)
inphase = np.sin(2 * np.pi * s / 5000 * 8)
quadrature = np.cos(2 * np.pi * s / 5000 * 8)
m1 = np.array([1, 1, 1, 1, 0, 0, 0, 0], dtype=np.uint8)
m1 = np.tile(m1, 625)
m2 = np.roll(m1, 1)
m3 = np.roll(m1, 2)
m4 = np.roll(m1, 3)
# create XML header
# require structure for WFMX header
df = ET.Element('DataFile')
dsc = ET.SubElement(df, 'DataSetsCollection')
dss = ET.SubElement(dsc, 'DataSets')
dss.attrib = {'version': '1'}
dd = ET.SubElement(dss, 'DataDescription')
ns = ET.SubElement(dd, 'NumberSamples')
ns.text = '2400'
su = ET.SubElement(df, 'Setup')
# optional parts of WFMX header
mi = ET.SubElement(dd, 'MarkersIncluded') # optional, default 'false'
mi.text = 'false' # has marker vector
ts = ET.SubElement(dd, 'Timestamp')
ts.text = datetime.datetime.now().isoformat()
ps = ET.SubElement(dss, 'ProductSpecific') # optional
sf = ET.SubElement(ps, 'SignalFormat') # optional, default 'real'
sf.text = 'Real' # 'IQ' for complex
rsr = ET.SubElement(ps, 'RecSamplingRate') # optional
rsr.attrib = {'units': 'Hz'}
rsr.text = '1230400000'
ra = ET.SubElement(ps, 'RecAmplitude') # optional
ra.attrib = {'units': 'Volts'}
ra.text = '0.487'
ro = ET.SubElement(ps, 'RecOffset') # optional
ro.attrib = {'units': 'Volts'}
ro.text = '0.123'
# write an idle waveform
with open('my idle waveform.wfmx', 'wb') as f:
    f.write(ET.tostring(df)) # write xml header
    f.write(idle_wfm.tobytes()) # write vector 1 bytes
# write a complex waveform
# update xml header for complex format
ns.text = '5000'
sf.text = 'IQ'
with open('my complex waveform.wfmx', 'wb') as f:
    f.write(memoryview(inphase)) # write vector 1 bytes
    f.write(memoryview(quadrature)) # write vector 2 bytes
# write waveform with a marker vector
# pack markers
mAll = ((m1 & 0b1) << 0) + ((m2 & 0b1) << 1) + ((m3 & 0b1) << 2) + ((m4 & 0b1) << 3)
# update header with new infos
mi.text = 'true'
sf.text = 'Real'
with open('my sine with markers.wfmx', 'wb') as f:
    f.write(memoryview(mAll)) # write marker vector
# write a complex with markers
sf.text = 'IQ'
with open('my complex with markers.wfmx', 'wb') as f:
Please discuss.
