Python Make SEQX (ElementTree API)
Programming examples for remote communication with instruments
C/C++, C#, Python, Matlab, LabVIEW
Carl M
Post by Carl M » June 19th, 2018, 11:50 am
The Tektronix SEQX is a zip archive that contains 1 or more sequences (SML files) and optionally WFMX waveforms. This is intended to provide all channel assets (waveforms/sequences) defining a signal into a single file. SML files are an XML file that describes a sequence. Referenced assets are automatically loaded if available. Assets missing from the SEQX file will be replaced with assets currently loaded (from waveform list or sequence list). Assets missing from both will be reassigned to Empty. While you can pack many waveforms and sequences into a single SEQX file, a healthy habit is to only build SEQX files with one primary SML file and include only referenced assets.
Python has built-in tools for XML files and ZIP archives:
* https://docs.python.org/3/library/xml.html
* https://docs.python.org/3/library/zipfile.html
This example demonstrates of the ElementTree API and zipfile module to create a functioning SEXQ file. Numpy is used for creation of simplistic example vectors.
See also: Python Make WFMX (ElementTree API)
# demo: creating SEQX files
# for Tektronix AWG70000A and AWG5200 series
# SEQX structure
# a zip file, compression optional
# folder, Sequence, SML files (minamum 1 file)
# folder, Waveforms, WFMX files (optional)
# SML file: an XML file that contains seqence data
# demo seqence
# idle waveform, repeat inf, TrigA: goto 2
# positive pulse, once, goto 3
# idle waveform, repeat inf, TrigA: goto 3
# negative pulse, once, goto 1
import zipfile
import xml.etree.ElementTree as ET
import numpy as np # http://www.numpy.org/
# make waveforms for demo sequence
# see https://forum.tek.com/viewtopic.php?t=140605
idle_wfm = np.zeros(2400, dtype=np.single)
pos_pulse = idle_wfm
pos_pulse[0:10] = 1
neg_pulse = idle_wfm
neg_pulse[0:10] = -1
df = ET.Element('DataFile')
dsc = ET.SubElement(df, 'DataSetsCollection')
dss = ET.SubElement(dsc, 'DataSets')
dss.attrib = {'version': '1'}
dd = ET.SubElement(dss, 'DataDescription')
ET.SubElement(dd, 'NumberSamples').text = '2400'
su = ET.SubElement(df, 'Setup')
with open(r'C:\temp\idle.wfmx', 'wb') as f:
    f.write(ET.tostring(df))
    m = memoryview(idle_wfm)
    f.write(m)
with open(r'C:\temp\pos_pulse.wfmx', 'wb') as f:
    m = memoryview(pos_pulse)
    f.write(m)
with open(r'C:\temp\neg_pulse.wfmx', 'wb') as f:
    m = memoryview(neg_pulse)
    f.write(m)
# sml file
df.attrib = {'offset': '000000000', 'version': '0.1'}
ET.SubElement(dd, 'SequenceName').text = 'demo sequence'
ET.SubElement(dd, 'RecSampleRate').text = '10000000000'
steps = ET.SubElement(dd, 'Steps')
steps.attrib = {'StepCount': '4', 'TrackCount': '1'}
s = ET.SubElement(steps, 'Step')
ET.SubElement(s, 'StepNumber').text = '1'
ET.SubElement(s, 'Repeat').text = 'Infinite'
ET.SubElement(s, 'EventJumpInput').text = 'TrigA'
assets = ET.SubElement(s, 'Assets')
a = ET.SubElement(assets, 'Asset')
ET.SubElement(a, 'AssetName').text = 'idle' # name of WFMX file w/o extention
ET.SubElement(a, 'AssetType').text = 'Waveform'
ET.SubElement(s, 'StepNumber').text = '2'
ET.SubElement(a, 'AssetName').text = 'pos_pulse'
ET.SubElement(s, 'StepNumber').text = '3'
ET.SubElement(s, 'StepNumber').text = '4'
ET.SubElement(s, 'GoTo').text = 'First'
ET.SubElement(a, 'AssetName').text = 'neg_pulse'
# update size
actual_size = len(ET.tostring(df))
if actual_size > 999999999:
    raise Exception("sequence files cannot exceed 999,999,999 bytes")
df.attrib['offset'] = '{:09d}'.format(actual_size)
# write to file
with zipfile.ZipFile(r'C:\temp\my_seq.seqx', mode='w') as zo:
    zo.writestr('Sequences/main.sml', ET.tostring(df))
    zo.write(r'C:\temp\idle.wfmx', 'Waveforms/idle.wfmx')
    zo.write(r'C:\temp\pos_pulse.wfmx', 'Waveforms/pos_pulse.wfmx')
    zo.write(r'C:\temp\neg_pulse.wfmx', 'Waveforms/neg_pulse.wfmx')
Please discuss.
Return to “Remote Instrument Communication (Programming) Examples”
