Python Read/Write AFG TFW
Programming examples for remote communication with instruments
C/C++, C#, Python, Matlab, LabVIEW
Carl M
Post by Carl M » August 30th, 2018, 1:31 pm
Tektronix AFGs use TFW files to store shape-data (i.e. sample vector). It is a simplistic binary consisting of a 512 byte header followed by a series of 2-byte unsigned big-endian values. The header contains some static identifiers, the number of samples, and an optional waveform envelope used for the arb plot on the AFG display. As of posting, all current Tektronix AFGs are 14-bit dynamic range so the upper two bits are unused. TFW files can be referenced from USB storage or transferred to internal storage. We have a video guide on saving and recalling on the AFG3000 series: https://youtu.be/lO67PZZIftg
# functions for reading and writing TFW files
# AFG1k, AFG2k, AFG3ks
# TFW files are a simplistic binary
# they only contain shape data
# amplitude, offset, and timing are applied at run-time by AFG settings
# https://www.tek.com/sample-license
import struct
import numpy as np  # http://www.numpy.org/
class TFW_Read_Error(Exception):
    """general error for TFW file operations"""
    pass
def read_tfw(target):
    """open target file and return numpy array of digital dac values"""
    with open(target, 'rb') as f:
        h = f.read(512)
        if len(h) != 512:
            raise TFW_Read_Error('file too small')
        m = struct.unpack_from('>10s6x3I', h)
        if m[0] != b'TEKAFG3000':
            raise TFW_Read_Error('missing TFW identifier "TEKAFG3000"')
        if m[1] != 20050114:
            raise TFW_Read_Error('version not 20050114')
        samples = m[2]
        dac_values = np.fromfile(f, dtype='>u2', count=samples)
    return dac_values
def normal_vector(vector, ymax=16382, ymin=0, dtype='>u2'):
    """normalize vector to integer values between ymin and ymax"""
    m = (ymax - ymin) / (vector.max() - vector.min())
    b = ymax - (m * vector.max())
    n = m * vector + b
    n = np.array(n, dtype=dtype)
    return n
def envelope_vector(dac_values):
    """return envelope vector from dac_values"""
    # envelope is maximum 206 uint8 min-max pairs
    n = np.array(dac_values >> 6, dtype=np.uint8)
    if len(dac_values) <= 206:
        upper = n
        lower = n
    else:
        segments = np.array_split(n, 206)
        upper = np.zeros(206, dtype=np.uint8)
        lower = np.zeros(206, dtype=np.uint8)
        for i, s in enumerate(segments):
            upper[i] = s.max()
            lower[i] = s.min()
    c = np.vstack((lower, upper)).reshape(-1, order='F')
    return c
def write_tfw(target, dac_values):
    """write target file in TFW format with dac_values"""
    d = np.array((dac_values & 0x3fff), dtype='>u2') # cast and mask
    samples = len(d)
    # an envelope vector is used for arb plot on AFG
    envelope = envelope_vector(d)
    header = bytearray(512)
    struct.pack_into('>10s6x3I',    # format
                     header,        # buffer
                     0,             # offset
                     b'TEKAFG3000', # magic bytes
                     20050114,      # version
                     samples,       # length
                     1)             # envelope flag
    header[28:28+len(envelope)] = memoryview(envelope)
    with open(target, 'wb') as f:
        f.write(header)
        f.write(memoryview(d))
def write_tfw_no_envelope(target, dac_values):
    """write target file in TFW format with dac_values omitting envelope"""
    samples = len(d)
                     header,        # buffer
                     0,             # offset
                     20050114,      # version
                     samples,       # length
                     0)             # envelope flag
        f.write(header)
def example_usage(file = 'example.tfw'):
    samples = 1200
    cycles = 32
    t = np.arange(samples, dtype=np.uint16)
    y = np.sin(np.pi * t / samples) * np.sin(2 * np.pi * t / samples * cycles)
    n = normal_vector(y)
    write_tfw(file, n)
Return to “Remote Instrument Communication (Programming) Examples”
