Python Read WFM File (oscilloscope)
Carl M
Post by Carl M » October 1st, 2018, 11:48 am
This is a proof-of-concept module and examples demonstrating extraction of voltage vs time records from little-endian version 3 *.WFM files. It also supports FastFrame records and the trigger time stamp information.
For a full definition of the Tektornix oscilloscope *.WFM file, refer to the Performance Oscilloscope Reference Waveform File Format manual (Tektronix part # 077-0220-10, https://www.tek.com/oscilloscope/dpo700 ... e-manual-4)
please note: Tektronix AWGs share use of the '.WFM' file extension but have a different structure.
AWG WFMs are defined in the AWG400/500/600 Series Programmer Manual Manual (070A81050, https://www.tek.com/awg410-manual/awg40 ... mer-manual) on pdf page 161
# wfm reader proof-of-concept
# https://www.tek.com/sample-license
# reads volts vs. time records (including fastframes) from little-endian version 3 WFM files
# See Also
# Performance Oscilloscope Reference Waveform File Format
# Tektronix part # 077-0220-10
# https://www.tek.com/oscilloscope/dpo7000-digital-phosphor-oscilloscope-manual-4
import struct
import time
import numpy as np # http://www.numpy.org/
class WfmReadError(Exception):
    """error for unexpected things"""
    pass
def read_wfm(target):
    """return sample data from target WFM file"""
    with open(target, 'rb') as f:
        hbytes = f.read(838)
        meta = decode_header(hbytes)
        # file signature checks
        if meta['byte_order'] != 0x0f0f:
            raise WfmReadError('big-endian not supported in this example')
        if meta['version'] != b':WFM#003':
            raise WfmReadError('only version 3 wfms supported in this example')
        if meta['imp_dim_count'] != 1:
            raise WfmReadError('imp dim count not 1')
        if meta['exp_dim_count'] != 1:
            raise WfmReadError('exp dim count not 1')
        if meta['record_type'] != 2:
            raise WfmReadError('not WFMDATA_VECTOR')
        if meta['exp_dim_1_type'] != 0:
            raise WfmReadError('not EXPLICIT_SAMPLE')
        if meta['time_base_1'] != 0:
            raise WfmReadError('not BASE_TIME')
        tfrac_array = np.zeros(meta['Frames'], dtype=np.double)
        tdatefrac_array = np.zeros(meta['Frames'], dtype=np.double)
        tdate_array = np.zeros(meta['Frames'], dtype=np.int32)
        tfrac_array[0] = meta['tfrac']
        tdatefrac_array[0] = meta['tdatefrac']
        tdate_array[0] = meta['tdate']
        # if fastframe, read fastframe table
        if meta['fastframe'] == 1:
            WUSp = np.fromfile(f, dtype='i4,f8,f8,i4', count=(meta['Frames'] - 1))
            # merge first frame trigger infos with frames > 1
            tfrac_array[1:] = WUSp['f1']
            tdatefrac_array[1:] = WUSp['f2']
            tdate_array[1:] = WUSp['f3']
        # read curve block
        bin_wave = np.memmap(filename = f,
                             dtype = meta['dformat'],
                             mode = 'r',
                             offset = meta['curve_offset'],
                             shape = (meta['avilable_values'], meta['Frames']),
                             order = 'F')
        # close file
    # slice out buffer values
    bin_wave = bin_wave[meta['pre_values']:meta['avilable_values'] - meta['post_values'],:]
    scaled_array = bin_wave * meta['vscale'] + meta['voffset']
    return scaled_array, meta['tstart'], meta['tscale'], tfrac_array, tdatefrac_array, tdate_array
def decode_header(header_bytes):
    """returns a dict of wfm metadata"""
    wfm_info = {}
    if len(header_bytes) != 838:
        raise WfmReadError('wfm header bytes not 838')
    wfm_info['byte_order'] = struct.unpack_from('H', header_bytes, offset=0)[0]
    wfm_info['version'] = struct.unpack_from('8s', header_bytes, offset=2)[0]
    wfm_info['imp_dim_count'] = struct.unpack_from('I', header_bytes, offset=114)[0]
    wfm_info['exp_dim_count'] = struct.unpack_from('I', header_bytes, offset=118)[0]
    wfm_info['record_type'] = struct.unpack_from('I', header_bytes, offset=122)[0]
    wfm_info['exp_dim_1_type'] = struct.unpack_from('I', header_bytes, offset=244)[0]
    wfm_info['time_base_1'] = struct.unpack_from('I', header_bytes, offset=768)[0]
    wfm_info['fastframe'] = struct.unpack_from('I', header_bytes, offset=78)[0]
    wfm_info['Frames'] = struct.unpack_from('I', header_bytes, offset=72)[0] + 1
    wfm_info['summary_frame'] = struct.unpack_from('h', header_bytes, offset=154)[0]
    wfm_info['curve_offset'] = struct.unpack_from('i', header_bytes, offset=16)[0] # 838 + ((frames - 1) * 54)
    # scaling factors
    wfm_info['vscale'] = struct.unpack_from('d', header_bytes, offset=168)[0]
    wfm_info['voffset'] = struct.unpack_from('d', header_bytes, offset=176)[0]
    wfm_info['tstart'] = struct.unpack_from('d', header_bytes, offset=496)[0]
    wfm_info['tscale'] = struct.unpack_from('d', header_bytes, offset=488)[0]
    # trigger detail
    wfm_info['tfrac'] = struct.unpack_from('d', header_bytes, offset=788)[0] # frame index 0
    wfm_info['tdatefrac'] = struct.unpack_from('d', header_bytes, offset=796)[0] # frame index 0
    wfm_info['tdate'] = struct.unpack_from('I', header_bytes, offset=804)[0] # frame index 0
    # data offsets
    # frames are same size, only first frame offsets are used
    dpre = struct.unpack_from('I', header_bytes, offset=822)[0]
    wfm_info['dpre'] = dpre
    dpost = struct.unpack_from('I', header_bytes, offset=826)[0]
    wfm_info['dpost'] = dpost
    readbytes = dpost - dpre
    wfm_info['readbytes'] = readbytes
    allbytes = struct.unpack_from('I', header_bytes, offset=830)[0]
    wfm_info['allbytes'] = allbytes
    # sample data type detection
    code = struct.unpack_from('i', header_bytes, offset=240)[0]
    wfm_info['code'] = code
    bps = struct.unpack_from('b', header_bytes, offset=15)[0]  # bytes-per-sample
    wfm_info['bps'] = bps
    if code == 7 and bps == 1:
        dformat = 'int8'
        samples = readbytes
    elif code == 0 and bps == 2:
        dformat = 'int16'
        samples = readbytes // 2
    elif code == 4 and bps == 4:
        dformat = 'single'
        samples = readbytes // 4
    else:
        raise WfmReadError('data type code or bytes-per-sample not understood')
    wfm_info['dformat'] = dformat
    wfm_info['samples'] = samples
    wfm_info['avilable_values'] = allbytes // bps
    wfm_info['pre_values'] = dpre // bps
    wfm_info['post_values'] = (allbytes - dpost) // bps
    return wfm_info
Carl M
Re: Python Read WFM File (oscilloscope)
Post by Carl M » October 1st, 2018, 11:51 am
You can download all code, example waveforms, and screencaptures of expected output in a single zip archive: https://fortive.box.com/shared/static/i ... wg9t7x.zip
# tekwfm.py usage examples
import time
import matplotlib.pyplot as plt # https://matplotlib.org/
import tekwfm
def demo1(myfile):
    """print date of trigger and plot scaled wfm 'myfile'"""
    volts, tstart, tscale, tfrac, tdatefrac, tdate = tekwfm.read_wfm(myfile)
    # print trigger time stamp
    print('local trigger time for: {}'.format(myfile))
    print('trigger: {}'.format(time.ctime(tdate)))
    # create time vector
    toff = tfrac * tscale
    samples, frames = volts.shape
    tstop = samples * tscale + tstart
    t = np.linspace(tstart+toff, tstop+toff, num=samples, endpoint=False)
    # plot
    plt.figure(1)
    plt.axvline(linewidth=1, color='r') # trigger annotation
    plt.plot(t, volts)
    plt.xlabel('time (s)')
    plt.ylabel('volts (V)')
    plt.title('single waveform')
    plt.show()
def demo2(myfile):
    """plot frame 0 vs all frames on a two plot figure with locked time axes"""
    # print trigger time stamps
    print('local trigger times for: {}'.format(myfile))
    for frame, utcseconds in enumerate(tdate):
        print('frame: {:02d}, trigger: {}'.format(frame, time.ctime(utcseconds)))
    t = np.linspace(tstart, tstop, num=samples, endpoint=False)
    # fractional trigger
    times = np.zeros(volts.shape)
    for frame, subsample in enumerate(tfrac):
        toff = subsample * tscale
        times[:,frame] = t + toff
    # plot: fastframe
    plt.figure(2)
    ax1 = plt.subplot(2, 1, 1)
    ax1.axvline(linewidth=1, color='r') # trigger annotation
    ax1.plot(times[:,0], volts[:,0])
    plt.title('only frame 1')
    ax2 = plt.subplot(2, 1, 2, sharex=ax1)
    ax2.axvline(linewidth=1, color='r') # trigger annotation
    ax2.plot(times, volts)
    plt.title('all frames')
    plt.show()
def demo3(myfile):
    """plot fastframe record on continuous time scale.
not very practical for high frame counts or large delays between triggers"""
    # scale trigger times to first frame
    ref_frame = 0
    tdate -= tdate[ref_frame]
    tdatefrac -= tdatefrac[ref_frame]
    # the following operation reduces resolution
    # this may not be suitable for high frame counts
    # or acquisitions with large delays between triggers
    tdateall = tdate + tdatefrac
    times += tdateall # shift sample times
    # plot
    plt.figure(3)
    plt.plot(times, volts)
    plt.title('all frames, continuous time')
    plt.show()
def demo4(myfile):
    """plot bar chart of time between frames"""
    x = np.arange(1, frames)
    iseconds = np.diff(tdate)
    fseconds = np.diff(tdatefrac)
    fseconds += iseconds
    # bar plot
    plt.figure(4)
    plt.bar(x, fseconds)
    #plt.xticks(x)
    plt.xlabel('diff(frame)')
    plt.ylabel('time (s)')
    plt.title('time between frames')
    plt.show()
Carl M
Post by Carl M » October 1st, 2018, 11:56 am
expected output of sample wfm files
