fca3000 can't set continuos measurement for both channel
Michael Piran
Country: Italy
Post by Michael Piran » October 9th, 2018, 7:39 am
Hi :) ,
In my Python program, I would continuos read two frequency from a Tektronix fca3000 and later I would plot them. I comunicate with a USB interface.
Thank's to totalize[Contiuos], I can read a continuos measurement on channe1 (or A). When I try the same scripts for channel 2 the instruments continue read from channel 1.
What's the problem? Fca3000 can't read continuosly from two channel?
import visa
from matplotlib import pyplot as plt
import matplotlib.animation as animation
import numpy as np
rm = visa.ResourceManager()
print(rm.list_resources())
inst = rm.open_resource('USB::0x0699::0x3000::170411::INSTR')
print(inst.query("*IDN?"))
inst.timeout = 20000
inst.write("*RST\n")
inst.write("*CLS\n")
aperture = inst.query_ascii_values('FREQuency:BURSt:APERture?')
inst.write('CONFigure:ARRay:FREQuency:BURSt 2000')
inst.write('FORMat:TINFormation ON')
inst.write('CONFIGURE:TOTALIZE[:CONTINUOUS] (@1)') #continuos measure on ch.A
inst.write('INIT:CONT ON')
inst.write('TOT:GATE ON')
data = []
def data_gen(tzero_f = 1):
    while True:
        isFreq = 1
        data = inst.query_ascii_values('FETCH:ARRay? -2')#fetch the last 2 value
        for value in data:
            if isFreq==1:
                #req = value * (60 / 360); # RPM
                freq = value
                isFreq = 0
            else:
                if tzero_f==1:
                    timezero=value
                    tzero_f = 0
                time = value-timezero
                isFreq = 1
        yield time,freq
def init():
    ax.set_ylim(0,10)
    ax.set_xlim(0, 10)
    del xdata[:]
    del ydata[:]
    line.set_data(xdata, ydata)
    return line,
fig = plt.figure()
ax = fig.add_subplot(1,1,1)
line, = ax.plot([], [], lw=2)
plt.grid()
plt.xlabel('time (s)')
plt.ylabel('Frequency')
plt.title('CH1')
xdata, ydata = [], []
def run(data):
    # update the data
    t, y = data
    xdata.append(t)
    ydata.append(y)
    xmin, xmax = ax.get_xlim()
    ymin, ymax = ax.get_ylim()
    if t >= xmax:
        ax.set_xlim(xmin, 2*xmax)
        ax.figure.canvas.draw()
    if y >= ymax:
        ax.set_ylim(ymin, 2*ymax)
    return line
ani = animation.FuncAnimation(fig, run, data_gen, blit=False, interval=10,
                              repeat=False, init_func=init)
plt.show()
Carl M
Re: fca3000 can't set continuos measurement for both channel
Post by Carl M » November 7th, 2018, 10:36 am
be sure to check the event status register (*esr?) to check for errors on the instrument end. if the reply is non-zero, read the event messages with system:error? until the instrument replies "no error"
