TEKVISA doesn't Detect RSA306
tiktek
Country: Israel
Post by tiktek » February 26th, 2018, 5:57 am
I'm trying to control RSA306 from Labview and followed the exact procedure posted in this forum (viewtopic.php?t=138345), however after installing all the drivers and programs and opening SignalVu, still TEKVISA doesn't detect the RSA306. All it finds is GPIB8::1::INSTR which identifies as "TEKTRONIX,SignalVu-PC,66db9344, FV:3.13.0072.0"
I'm using Labview 2017 64bit on Win10 Pro.
Any help will be appreciated :)
Thanks.
w2aew
Re: TEKVISA doesn't Detect RSA306
Post by w2aew » February 26th, 2018, 6:40 am
When using TekVISA to communicate with the RSA306B, programmatic control via SignalVu-PC is the correct way to go. The programmers manual can be found here:
https://www.tek.com/spectrum-analyzer/r ... nalvu-pc-0
Dave W
Post by Dave W » October 26th, 2018, 8:29 am
Hi tiktek. That is correct, you will see the device identified as SignalVu-PC as it is SignalVu-PC you are communicating with which in turn controls the RSA306 hardware. You will never see RSA306 identified in VISA.
Return to “RSA Programming”
