Kiwave v1.2 send waveform dialog does not pops up
ArbExpress, OpenChoice Desktop, ExceLINX, LabTracer, KI-Wave, KI-Tool, etc.
weizhig
Country: Australia
Post by weizhig » May 9th, 2018, 6:40 pm
HI,
I am trying to send a user-defined waveform from a laptop to a device (keithley 3390 arbitrary waveform generator) using a USB interface.
when I press the button "send waveform", "send waveform" dialog window does not pop up, and therefore I am not able to output a waveform from a laptop to the device?
Can you help me with this problem, please?
Kind regards
weizhi
Stuart M
Re: Kiwave v1.2 send waveform dialog does not pops up
Post by Stuart M » May 10th, 2018, 10:40 am
Prerequisites for using KI-Wave:
1. Install NI-VISA (e.g. NI-VISA 17.5)
2. Install Java SE Runtime (e.g. Java 8 Update 171) (32-bit)
3. Connect your 3390 to your pc (in this case will detail using USB connction)
4. Download KI-Wave and install
5. Open NI-VISA Interactive Control and verify that you see your instrument listed at the bottom of the list under USB Instrument Resources as USB0::0x5E6::0x3390::nnnnnnnnnnnn::INSTR (where nnnnnn is the serial number of your instrument)
Using KI-Wave
6. Start KI-Wave
7. Configure and add waveform segments to create a waveform
8. Press the "Send waveform to your instrument" button
9. The Send Waveform to Instrument... dialog will then appear with the Connect to choices at the top. Be sure to select USB0...
10. Press the Send button at the bottom of the dialog
11. Waveform will be sent to instrument
If Still Having Problems...
- what operating system do you have?
- what version of firmware is on your 3390?
- what version of java did you install?
- is the jave SE 32-bit or 64-bit?
weizhig
Country: Australia
Post by weizhig » May 10th, 2018, 8:44 pm
I still have problem, that is the 'send waveform' dialog window still not pops up. I have done everything in the checklist you made.
my lapton is 64-bit, so I install 64-bit Java both JDK and JRE.
by the way, how to check the firmware for my 3390?
kind regard
weizhi
Stuart M
Post by Stuart M » May 11th, 2018, 10:39 am
Seems there is some confusion.
Not sure what Operating System you are using...is it windows 7 or windows 10 or ?
Whether it is 64-bit or 32-bit, but the actual KI-Wave app is 32-bit and needs 32-bit Java.
Install 32-bit Java and see if it helps.
Also, have you successfully installed NI-VISA?
Can you successfully connect to your instrument NI-VISA Interactive control?
Return to “Other and Discontinued Software”
