KIWave_Version_1.1_setup.exe Unattended Install Help Needed
Posted: October 24th, 2012, 6:57 am
I am looking for assistance in performing an unattended install of KIWave_Version_1.1_setup.exe for the Keithley 3390.
OS is Windows 7 SP1 32 bit
This installer seems to be a NSIS (nullsoft scriptable install system) based installer.
Are there command line switches will will enable an unattended hands free installation? In my application monitor and keyboard are disabled so even a GUI based automation is not possible.
I tried (paying attention to CASE of the applied switches)
KIWave_Version_1.1_setup.exe /S
KIWave_Version_1.1_setup.exe /SD
This resulted in a window
Window Title was 16 bit MS-DOS Subsystem
"Administrator:C:\Windows\system32\cmd.exe KIWAVE_version_1.1_setup.exe /S
The NTVDM CPU has encountered an illegal instruction.
CS:087b IP:0109 OP:8f be 0e e2 85 Choose 'Close' to terminate the application."
Based on documentation I read on NSIS there does not seem to be the ability to create an answer file. Need assistance please
