Triax or Quadrax connectors on S400 Relay Matrix card
S530 Parametric Test Systems
a0196053
Post by a0196053 » February 28th, 2013, 1:22 pm
I have an older Keithley S400 Parametric test systems and some of the connectors (Force, Measure, Guard and Shield, driven guard arrangement, two conductors F and S inside Teflon with shield/Guard around thes) broke off and I need to replace them but the parts has no part number or manufacturer name... do you know where I can buy some of these connectors (that lock onto the panel with a lock ring)? Thanks
Jane S
Re: Triax or Quadrax connectors on S400 Relay Matrix card
Post by Jane S » April 19th, 2013, 5:41 pm
Please check page 5 of the attached file. The attached file is our cable selector guide.
I hope this helps.
Jane
Acc_Cables.pdf
Cable Selector guide
(1.34 MiB) Downloaded 1668 times
Return to “S530 Parametric Test Systems”
