MSO58: save decoded data on trigger
MSO54, MSO56, MSO58
timopirr
Post by timopirr » January 4th, 2019, 2:49 am
I would like to save on trigger decoded data from a RS232 bus (baud=115200). The data comes 10x every second with 32byte data each package. The triggering and decoding works fine so far, but the saving options are pretty limited.
Is there a way to save (only the) decoded data in a csv-File in the following scenario?
The csv-File will be opened when the aquisition starts. The data on every trigger will be saved in a new row or column. The csv-File will be closed when the aquisitions ends.
I use firmware version: 1.8.7.5308 (2018-07-16)
Thanks in advance
Return to “5 and 6 Series MSO Oscilloscopes (including 5 Series Low Profile)”
