MSO58: SPI bus decode
MSO54, MSO56, MSO58
Doraemon
Country: Japan
Post by Doraemon » January 18th, 2019, 5:53 pm
Hello!
I'm using an MSO 58, and I don't know if I'm missing something, but doing something as basic as decoding a SPI bus
involves setting up 3 buses. 1 for CLK + MOSI, 1 for CLK + MISO, and one for CS. If I want to view both bus and signals,
I will end up with 2 clocks. If I want to trigger by idle time, yet having a CS displayed, then I need the 3rd bus mentioned
above. Is there a simpler way to do that?
I would expect that SPI is setup with a single bus, showing the 4 standard signals as it is the case on earlier scopes.
Is there a technical reason to split SPI in 2 separated buses?
Dora.
Return to “5 and 6 Series MSO Oscilloscopes (including 5 Series Low Profile)”
