3390 Waveform Generator - Sweep soft start/stop
Keithley 3390
luke.griffiths
Country: United Kingdom
Post by luke.griffiths » May 20th, 2014, 1:33 am
Hi there,
We have a 3390 Arbitrary waveform generator and would like to use the sweep function to generate a wave from 1kHz to 5kH over 3 seconds duration.
This is not a problem with the Sweep function but we would also like the wave to ramp up from 0V to 1V pk-pk in the first 0.2seconds and then ramp down from 1V pk-pk to 0V in the last 0.2 seconds.
Is there a way to do this using the 3390?
Luke
Re: 3390 Waveform Generator - Sweep soft start/stop
Post by Dale C » May 22nd, 2014, 10:25 am
I think the way to do this is to use the KI-WAVE software.
That way you can create your own waveform.
KI-WAVE is shipped with the unit.
If you do not have it then go to this link and down load it.
http://www.keithley.com/support/data?asset=52791
Return to “Keithley 3390”
