Model 3390 accuracy
Keithley 3390
pevans
Model 3390 accuracy
Post by pevans » September 14th, 2010, 6:44 am
What is the amplitude accuracy of the 3390 in the SINE wave mode?
Re: Model 3390 accuracy
Post by Dale C » September 14th, 2010, 1:29 pm
Model 3390 accuracy of 10mV at 10kHz is +/-1% of setting plus 1mVp-p.
I ran this with a 3390 into a Model 2700 DMM.
The output was 10.0mV and the reading on the DMM was 010.006mV.
Well within spec. One per cent would be 010.1mV.
basiljoseph
Post by basiljoseph » August 29th, 2011, 5:01 am
Keithley has paired the best-in-class performance of the Model 3390 Arbitrary Waveform/Function Generator with the best price in the industry to provide your applications with superior waveform generation functionality and flexibility at an unparalleled price. The Model 3390 is an easy-to-use programmable signal generator with advanced function, pulse, and arbitrary waveform capabilities. Superior signal integrity, faster rise and fall times, lower noise, and greater waveform memory combine to provide high quality output signals. High resolution waveforms are supported by four times the waveform memory of any competitive waveform generator on the market. From its fully featured arbitrary waveform generator (ARB) to its high speed and ease-of-use, the Model 3390 is a complete signal generation solution for all your waveform application needs up to 50MHz.
Return to “Keithley 3390”
