3390 Initial Sine Wave
Keithley 3390
amd426
Post by amd426 » May 20th, 2011, 2:56 pm
Assuming factory settings and a standard sine wave output (signal voltage = y(t) = V*sin(w*t)), does the 3390 always start at y(t=0) = 0V? If not, is there a way to force it to start that way every time?
Re: 3390 Initial Sine Wave
Post by Dale C » May 26th, 2011, 8:14 am
Set zero phase to zero.
On the front panel press UTILITY then select OUTPUT SETUP.
Then select ADJ PHASE, now select Set 0 Phase.
Set this to 0.0000 and it should start a zero each time.
amd426
Post by amd426 » May 26th, 2011, 9:33 am
Thanks Dale!
Return to “Keithley 3390”
