2380 IVI driver help
Series 2380 DC Electronic Loads
misko85
Country: Yugoslavia
Post by misko85 » July 3rd, 2020, 4:47 am
Hello everyone,
I have a problem using IVI drivers for 2380-500-30 in LabWindows/CVI IDE. I've successfully loaded the instrument (.fp file) into project, but each time I try to set some parameter, device goes to error mode (ERROR mark is activated on display), which cannot be cleared until the device power is cycled. I managed to read measurements without any problem, but each time the command is sent it goes to error. Does anyone have any sample code I could use? The examples which came with the drivers are covering only .dll implementation. Thanks!
Miodrag
misko85
Country: Yugoslavia
Re: 2380 IVI driver help
Post by misko85 » July 3rd, 2020, 6:23 am
I've detected possible source of the problem. The device has to be activated in Remote operation mode, but the command is ignored when I try to do so using keyboard commands. I cannot find any function in instrument .fp driver which activates Remote mode...
Return to “Electronic Loads”
