2380 battery mode
Series 2380 DC Electronic Loads
velinr
Country: Bulgaria
2380 battery mode
Post by velinr » September 25th, 2018, 5:38 am
2380 battery mode has 3 criteria (voltage, capacity and time) for terminating the discharge. Is it possible to set only one of them as active? So far my experience shows that I have to set all of them (with some value) to start discharge. Most of the time there is no need for all criteria to be active.
Also, is there any plans for Constant resistance and Constant power to be supported in battery mode? It could be usefull for some applications/measurements.
Return to “Electronic Loads”
