I have downloaded the driver for the Tektronik MSO 4104 from Mathworks. I can get the data and can change the window-timebase.
So the connection to the oscilloscope is established and working.
But I have problems when I want to set the scale of the oscilloscope:
My course of action:
I have opened the "tmtool" and created a new Device Object by using the driver.
Then I have chosen the property "Scale".
At this moment there is an error message:
"The dependent property Probe was not found while saving the Scale property in the channel group."
Then I tried a different approach:
I opened the deviceOBJ (double click on deviceObj in the Workspace) and chose "Channel", then I wanted to increase the Scale.
This caused an Exception:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
What am I doing wrong?
Or is there a other way to set the scale?
Set scale of oscilloscope via TekVISA
OpenChoice TekVISA
- Country: Germany
Jump to
- Announcements
- Customer Support
- ↳ Product Support
- ↳ Oscilloscopes
- ↳ Programming Support
- ↳ Passive/Low Voltage
- ↳ High Voltage
- ↳ Differential
- ↳ Current
- ↳ Signal Sources
- ↳ AFG1000/2000/3000 series
- ↳ AWG5000/7000/70000 Series
- ↳ Keithley 3390
- ↳ TSG4100A Series
- ↳ AFG31000 Series
- ↳ Spectrum Analyzers
- ↳ Announcements and FAQs
- ↳ RSA Programming
- ↳ RSA5000/6000 Series
- ↳ Vector Network Analyzers
- ↳ TTR500 Series VNAs
- ↳ 2600 Series SourceMeter
- ↳ 2400 Series SourceMeter
- ↳ DMM6500 Bench/System DMM
- ↳ Other DMM's
- ↳ 7000 Series Switch
- ↳ 700 Series Switch
- ↳ RF Switch
- ↳ Other Switches
- ↳ Power Supplies
- ↳ Series 2300
- ↳ Other Power Supplies
- ↳ Power Analyzers
- ↳ ACS Software Products
- ↳ Nanovoltmeters
- ↳ Electrometers
- ↳ Curent Amplifiers
- ↳ PicoAmmeters
- ↳ Current Sources
- ↳ Bit Error Rate Testers
- ↳ Logic Analyzers
- ↳ Other Instruments
- ↳ Electronic Loads
- ↳ Frequency Counters
- ↳ Software
- ↳ TekScope Anywhere
- ↳ SourceXpress
- ↳ SignalVu-PC
- ↳ PWRVIEW
- ↳ KickStart
- ↳ Test Script Builder
- ↳ LabView Drivers
- ↳ IVI Drivers
- ↳ TekVISA
- ↳ ExcelLINX
- ↳ IVy
- ↳ Keithley I/O Layer (KIOL)
- ↳ Accessories
- ↳ Test Fixtures
- ↳ Cables and Connectors
- ↳ Application Support
- ↳ Low Current Measurements
- ↳ Low Voltage Measurements
- ↳ Resistivity Measurements
- ↳ Hall Measurements
- ↳ Electrochemistry
- ↳ Solar Cell Measurements
- ↳ High Brightness LEDs
- ↳ General Discussion
