The attached Excel+VBA example does the following:
• Uses an RS-232 port to connect to the DMM6500
• DMM6500 is configured with a 2001-TCSCAN card, channels 2-4 have type K TCs
• The program runs for 2 hours, sampling channels 1 – 4 (including 1 for CJC)
• The DMM is periodically polled (once per second to check for new readings
• When new readings are available, the table is updated
• When the table is updated, the graphed channels are updated accordingly
Excel+VBA Example: Temperature Monitoring with the 2001-TCSCAN
- Attachments
- DMM6500_Temperature_Scan_Serial_Interface.xlsm
- (40.09 KiB) Downloaded 1249 times
