KickStart
zvikae
Country: Israel
KickStart
Post by zvikae » August 2nd, 2018, 7:30 am
Hi.
I have 2 questions regarding KickStart.
1. After scan how can I save the measured data with channels name/number ?
2. If customer buys the DAQ6510 is the license for KickStart a permanent one ?
Jennifer C
Re: KickStart
Post by Jennifer C » August 3rd, 2018, 11:45 am
HI Zvika,
You can export the data using the “Export” button available in the Run History menu. This should export with the expected channel number and name.
If someone buys a DAQ6510 and also a KICKSTARTFL-BASE license, then the KICKSTARTFL-BASE license is discounted to $0. This license is permanent, not time limited to 60 or 90 days. It is a floating license and the user manages assignment to individual PCs using Tektronix Asset Management System (TekAMS).
Let me know if you have further questions.
Regards,
Jennifer
