DMM6500 LabView Read (Multiple Item) error: trigger model
[email protected]
Country: Belgium
Post by [email protected] » January 22nd, 2019, 11:35 am
I'm testing the LabVIEW example in Keithley's DMM6500 driver lib: Keithley DMM6500 DAQ6500 Series General Scanning.vi
(I have tried simpler examples of the lib before and they work).
I've set the pseudocard to 0 because no card installed.
The example runs fine until step Read (Multiple Item)
When I enter that point, the error signal is still green, all ok.
Before the Read (Multiple Item)
When I execute Read (Multiple Item) I get this error:
Error:
Instrument reports:
2710,"Unable to initiate, no block number 1 in trigger model;1;2019/01/22 20:32:57.568"
0,"No error;0;0 0"
Complete call chain:
Keithley DMM6500 DAQ6500 Series.lvlib:Error Query.vi
Keithley DMM6500 DAQ6500 Series.lvlib:Query Operation Complete.vi
Keithley DMM6500 DAQ6500 Series.lvlib:Read (Multiple Points).vi
After the Read (Multiple Item)
When I change the Read to Single Item and change the output to a normal indicator it works. The error appears for Multiple Item only.
I've attached a screen capture before and after the Read block.
What error do I make?
