current auto-range
DMM6500 6½-Digit Touchscreen Multimeter
zvikaef
Country: Israel
current auto-range
Post by zvikaef » March 29th, 2020, 12:25 am
hi.
when measuring current using auto-range, is there interruption in current flow when the instrument changes ranges ?
Re: current auto-range
Post by Andrea C » March 31st, 2020, 9:47 am
I did a quick test using a 2450 SourceMeter to do a 0-5V voltage sweep on 110Ω with the DMM6500 wired in series as DC Amp meter.
I tested both fixed 100mA range and auto range on the DMM.
The SMU was fixed ranges for both sourcing and measuring.
Simple setup sketch:
setup
Outcomes:
compare 2450 to DMM
Return to “DMM6500 Bench/System DMM”
