I am using two dmm6500 instruments to measure power by using TSP-link and running LabVIEW 2015 (see manual: Measuring power using digitizing and TSP-link) . My problem is that I get error message "input buffer overrun".
I guess the error message is due to too long string that i am trying to send with single visa write. However I am noob with LABview so does anyone have any ideas on how to split script into smaller parts.
DMM6500 input buffer overrun
Re: DMM6500 input buffer overrun
Okei I solved problem by loading a script using a USB flash drive. But now a new problem has occurred when I try to run the script using LabVIEW I get "warning 1409 Aborted the running script". The script is named as measure_power so why it does not work when I try to write buffer measure_power.run().
