How PC to read result from DAQ6510, when TSP Script running.
DAQ6510 6½-Digit Data Acquisition and Logging Multimeter System
thomas_pancala
Country: Taiwan
Post by thomas_pancala » July 17th, 2021, 2:47 am
I hope to use PC to read the scanning results when TSP Script is under running.
Scanning Card: 7700
I try to use pc to scan and read, the command and procedure is OK.
I try to use PC to read the scanning results when TSP Script is under running. But failed.
Who can know how to do it?
Re: How PC to read result from DAQ6510, when TSP Script running.
Post by Andrea C » July 17th, 2021, 8:05 am
Curious for how fast are you scanning?
And in general, what is the use case? Is it a very long duration scan and you just want data during it?
The TSP script that runs on the instrument should avoid use of waitcomplete() as new commands sent from PC will not be processed during the wait.
You’ll most likely need to use the defbuffer1.n value to know the how much data is available.
Return to “DAQ6510 Data Acquisition and Logging Multimeter System”
