Monitoring the conditions (temperature, voltage, etc.) of your device under test (DUT) is made easy with the DAQ6510, but what about automating the setup of environmental conditions? This is a definite possibility when pairing the DAQ with one of the TestEquity environmental chambers.
In this latest piece from the Keithley team, we discuss an in-depth setup where the DAQ6510 remotely controls the temperature chamber via LAN connection and the chamber's SCPI command set. We show how the DAQ is programmed to run without a PC to...
* Perform measurement scans
* Set temperature levels
* Apply soak and/or ramp times
* And initiate scans based on either the DUT temperature or the process value reported by the chamber
DAQ6510 Script to Control TestEquity Environmental Chambers
- Attachments
- F4T_EnvController_DAQ6510.tsp
- (29.78 KiB) Downloaded 79 times
