Example: Excel + VBA Serial VISA Comms - DCV Scan with Model 2700
JBrown54
Keithley
Keithley
Post by JBrown54 » May 30th, 2018, 12:39 pm
Attached is an example of the following:
o Configures 10 channel DCV scan across 101-110
o Scan count 100 (10 readings each channel)
o Writes the channel data to cells in Excel spreadsheet
This example was created using Excel 2016 with VISA 17.5 + VISA-COM tools running behind the scenes. Serial comms has some additional settings, so hope this helps move some users along.
Keithley_Excel_VBA_Model2700_Serial_Comms_Example.xlsm
(27.65 KiB) Downloaded 576 times
