Duty Cycle measurement with 7708 card?
dprior
Post by dprior » November 21st, 2011, 9:09 am
Is there any possible way to perform a duty cycle measurement with a 2750 system and a 7708 card?
Nathan S
Re: Duty Cycle measurement with 7708 card?
Post by Nathan S » December 19th, 2011, 7:55 am
As an actual measurement, we do not have duty cycle as an option with your setup. You could take data and as high a sampling rate as the 2750 can do, either with your own software or ExceLINX, and they try to recreate the waveform or do your calculations with that, but I would guess that we could only really provide the sampling rate desired to do a waveform on the order of maybe 200Hz or even less. That is just an approximate guess, but it is one possible method of calculating duty cycle with the instruments you mentioned.
