Keithley 2701 Ethernet Multimeter/Data Acquisition System Ethernet Problem
Gibbs Choi
Country: South Korea
Post by Gibbs Choi » October 6th, 2015, 10:48 pm
Firmware upgrade A05 /A02 to B03 /A02.
After firmware upgrade the instrument shows the message "DHCP CONN... /" and that message is not stopped.
Rear panel LED is not blinking.
LAN Cable connection is not a problem because at the same connection status, I was upgrade firmware.
How can I fix it? :cry:
Re: Keithley 2701 Ethernet Multimeter/Data Acquisition System Ethernet Problem
Post by Dale C » October 7th, 2015, 8:05 am
I sent you a private message about this...
jpkeithley2456
Post by jpkeithley2456 » March 7th, 2016, 4:55 pm
Same problem, would it be possible to let me know the solution? Thank you. Firmware rev A09 A02.
Post by Dale C » March 8th, 2016, 6:11 am
This unit is in need of service.
Please contact the service department at 503-627-2445.
