DMM scaning and 7706 digital output.
careframe
Country: Canada
Post by careframe » August 16th, 2016, 10:12 am
We brought an Used Keithey 2700 with 7708 and 7706
I'm looking to send conditional binary output to 7706 chanel 21 and 22 with Excelinx to control relay operated power bar. when the test is finish and stop DMM Scan.
Can you help me if it possible to setup alarm or other thing.
We make burning test on woodstove and sometime Test finish after the end of the shift when scale return to the initial condition and we want to cut power to sample pump and other critical sampling probe.
Tanks in advance
Re: DMM scaning and 7706 digital output.
Post by Dale C » August 16th, 2016, 1:20 pm
Here is the manual for the 7706. that discusses the digital I/O and limits.
PA-719E_Mar2015_7706.pdf
(1.76 MiB) Downloaded 1144 times
