Cannot connect Keithley 2700 to PC
cedric.v
Country: Netherlands
Post by cedric.v » June 24th, 2019, 3:08 am
I am trying to connect the Keithley 2700 to a PC in order to acquire data. I am using a RS232 to USB cable, Win8.1 64bits, the settings on computer match those on the Keithley.
The problem is that the computer detect a device but it does not recognize it as a Kethley, nor in the device manager nor in Tektronix softwares (KickStart, Keithley communicator/configuration panel).
Does anyone have a solution for this problem ?
Re: Cannot connect Keithley 2700 to PC
Post by Andrea C » June 26th, 2019, 7:52 pm
When using RS-232, you will not see the 2700 that way. Just the COM port will be seen.
If using VISA IO, you might see a resource for the COM port such as ASRL1::INSTR
Try interacting with that.
You may need to put line feed on your commands to terminate them: *idn?\n
cedric.v
Post by cedric.v » June 27th, 2019, 1:28 am
Thank you, I have solved the problem by installing the right driver for the com port and I am mow able to communicate using the Keithley Communicator software.
NewArrow
Country: Moldavia
Post by NewArrow » November 8th, 2019, 7:51 am
Can you send the link for the driver?
