How to set Digital I/O to input or output?
ramgen
Post by ramgen » August 3rd, 2010, 7:47 am
I am looking in the reference manual of the Model 3706.
I cannot find information about how to set the digital I/O for
input or output?
Can you help?
Re: How to set Digital I/O to input or output?
Post by Dale C » August 3rd, 2010, 8:13 am
The following information and much more is available in the 3700 series reference manual, section 13, page 13-87.
The digital I/O lines can be used for both input and output. If a line is
being driven low, then a "0" value will be read by a command for that
line. You must write a "1" to all digital I/O lines that are to be used as
inputs.
