3723 Channel Pattren
zvikae
Country: Israel
Post by zvikae » October 5th, 2016, 12:17 am
Hello
In card 3723, is it possible to control "SINGLE POLE/DOUBLE POLE" relay with "channel.patren.setimage" command ?
Re: 3723 Channel Pattren
Post by Andrea C » October 11th, 2016, 6:51 am
You need to use the channel.setpole() command to affect the state of the single pole/double pole relays before you take the set the channel pattern image.
From the documentation on channel.pattern.setimage():
If you change a pole setting for a channel that is associated with a channel pattern, the channel pattern is
deleted. Be sure to configure the pole setting for channels (channel.setpole) before creating a channel pattern.
