3706A Connection Timeout
Bart Plovie
Country: Belgium
Post by Bart Plovie » May 9th, 2017, 8:19 am
I'm currently attempting to establish a connection with a 3706A (running firmware 1.51b - and not allowed to upgrade) from TSB, however I'm running into some significant issues. First I tried the web interface, which worked perfectly fine other than a few Java related bugs. Next I installed TSB and tried to add the 3706A as a LXI instrument on a computer running Windows 8.1. In the Keithley Configuration Panel wizard this resulted in a "VISA Read Error" with no additional information provided. When clicking next anyway I select the 3706A in the instrument list, sadly the software seems to disagree and it said I was using the wrong driver. Though given the fact that the device currently standing next to me says 3706A on the front panel this seems highly unlikely. Thinking it was a Windows 8.1 issue I used an older computer which comes with Windows XP and tried again with no success and the same error. In the meanwhile I verified that all network ports are open and everything seems to be working.
So next I went to grab the 3706A and put it on my desk and connected it to my desktop through USB, while the wizard is now willing to add it the other software seems to fail to recognise it automatically. Manually entering USB0::0x05E6::0x3706::01390768::INSTR as instrument in Keithley Communicator does seem to establish communication at this point, but not very successful as some *IDN? requests seem to result in timeouts. When doing this the device gives me -285 and -420 as error codes if I remember correctly. And the :SYST:ERR? requests Keithley Communicator automatically makes receive the same response. Running the "Test" option in the Configuration Panel Wizard returns an error stating the driver is wrong recommending me to change it, however this has no effect since I do in fact need to use the 3706A driver I suppose? (It's the unit with DMM and front panel with display.) I repeat this test on the Windows XP computer and everything progresses in the same fashion. Next I remove everything from Keithley and National Instruments and uninstall the hardware and disconnect it from the computer.
Based on the advice of a colleague I then first install KIOL, NI VISA 5.2 second, and finally TSB. The device now shows up in VISA Interactive Control with the address USB0::0x05E6::0x3706::01390768::INSTR. And I can open a session to the device and it'll happily read the USB and I/O settings. Doing a query with *IDN? here seems to work fine and returns "KEITHLEY INSTRUMENTS INC.,MODEL 3706A,01390768,01.51b\n". The same problem with Keithley Communicator (time outs seems to persist). So I try to open TSB again, this time I get an error stating:
Failed to retrieve list of available resources.
Unable to load Keithley Configuration Panel.
Install Keithley I/O Layer and try again.
Details: Failed to retrieve list of available resources.
com.keithley.KeithleyTSPLib.KeithleyTSPException: KeithleyTSPLib.KeithleyTSPException: Unable to load Keithley Configuration Panel.
Install Keithley I/O Layer and try again. ---> System.Runtime.InteropServices.COMException: Retrieving the COM class factory for component with CLSID {07818C4A-A5E2-11D4-8C0F-00A0C9050948} failed due to the following error: 800702e4 The requested operation requires elevation. (Exception from HRESULT: 0x800702E4).
at KeithleyTSPLib.IviConfigurationStore..ctor()
--- End of inner exception stack trace ---
at KeithleyTSPLib.TspClassDriver.GetResourceList()
at com.keithley.internal.dotnet.ProxyIKeithleyTspConfiguration.Java_com_keithley_internal_dotnet_ProxyIKeithleyTspConfiguration_GetResourceList(IntPtr pEnv, IntPtr pObj1)
KeTSP Driver version: 4.0.5850.18624
KIOL-850C07 is installed so this seems a weird error, but I press ok and I get the Select Instrument window, where I can select USB0::0x05E6::0x3706::01390768::INSTR. Clicking Ok it attempts to connect but quickly fails doing the following:
Failed to open instrument.
VISA reports:
Command `reset()' timed out waiting for instrument response.
KeithleyRemoteIO.VISAException: Command `reset()' timed out waiting for instrument response.
at KeithleyRemoteIO.InstrumentIO.SendCommand(String command)
at KeithleyRemoteIO.InstrumentIO.SendCommandReadResponse(String command)
at KeithleyRemoteIO.TspVisa.Initialize(String resourceName, Boolean idQuery, Boolean reset, StringDictionary optionStrings)
at KeithleyTSPLib.TspClassDriver.Initialize(String ResourceName, Boolean IdQuery, Boolean Reset, String OptionString)
at KeithleyTSPLib.KeithleyTSP.Initialize(String ResourceName, Boolean IdQuery, Boolean Reset, String OptionString)
at com.keithley.KeithleyTSPLib.KeithleyTSP.Java_com_keithley_KeithleyTSPLib_KeithleyTSP_Initialize(IntPtr pEnv, IntPtr pObj1, IntPtr pStr2, Boolean arg3, Boolean arg4, IntPtr pStr5)
This is the output I get from NI I/O Trace being on at the same time as TSB (first two lines are me doing an IDN request in the VISA Interactive Control (capture file attached):
1. viWrite (USB0::0x05E6::0x3706::01... (0x08634E48), "*IDN?.", 6, 6)
Process ID: 0x00000864 Thread ID: 0x00001A58
Start Time: 17:11:39.293 Call Duration 00:00:00.000
Status: 0 (VI_SUCCESS)
2. viRead (USB0::0x05E6::0x3706::01... (0x08634E48), "KEITHLEY INSTRUMENTS ...", 1024, 54)
Start Time: 17:11:39.337 Call Duration 00:00:00.000
3. viOpenDefaultRM (0x358E1520)
Process ID: 0x00000D1C Thread ID: 0x00001424
Start Time: 17:11:50.548 Call Duration 00:00:00.003
4. viOpen (0x358E1520, "USB0::0x05E6::0...01390768::INSTR", 4, 2000, 0x358DECD8)
Start Time: 17:11:50.551 Call Duration 00:00:00.002
5. viGetAttribute (USB0::0x05E6::0x3706::01... (0x358DECD8), INTF_TYPE, 7)
Start Time: 17:11:50.553 Call Duration 00:00:00.000
6. viGetAttribute (USB0::0x05E6::0x3706::01... (0x358DECD8), INTF_NUM, 0)
Start Time: 17:11:50.554 Call Duration 00:00:00.000
7. viWrite (USB0::0x05E6::0x3706::01... (0x358DECD8), "ABORT.", 6, 6)
8. viWrite (USB0::0x05E6::0x3706::01... (0x358DECD8), "ABORT.", 6, 6)
Start Time: 17:11:51.055 Call Duration 00:00:00.000
9. viWrite (USB0::0x05E6::0x3706::01... (0x358DECD8), "errorqueue.clear(); s...", 465, 465)
Start Time: 17:11:51.555 Call Duration 00:00:00.000
10. viRead (USB0::0x05E6::0x3706::01... (0x358DECD8), "97e2f7c7-5292-4709-b5...", 1024, 37)
Start Time: 17:11:51.555 Call Duration 00:00:00.002
11. viRead (USB0::0x05E6::0x3706::01... (0x358DECD8), "localnode.prompts=0.", 1024, 20)
Start Time: 17:11:51.557 Call Duration 00:00:00.000
12. viRead (USB0::0x05E6::0x3706::01... (0x358DECD8), "localnode.showerrors=0.", 1024, 23)
13. viRead (USB0::0x05E6::0x3706::01... (0x358DECD8), "--hasDebuggingSupport...", 1024, 36)
Start Time: 17:11:51.557 Call Duration 00:00:00.001
14. viRead (USB0::0x05E6::0x3706::01... (0x358DECD8), "--hasLocalnodeAccessP...", 1024, 35)
Start Time: 17:11:51.558 Call Duration 00:00:00.000
15. viRead (USB0::0x05E6::0x3706::01... (0x358DECD8), "TSP>.", 1024, 5)
16. viWrite (USB0::0x05E6::0x3706::01... (0x358DECD8), "reset()..", 9, 9)
Process ID: 0x00000D1C Thread ID: 0x00001048
Start Time: 17:11:51.759 Call Duration 00:00:00.001
17. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Process ID: 0x00000D1C Thread ID: 0x00001B10
Start Time: 17:11:51.760 Call Duration 00:00:00.003
18. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:51.964 Call Duration 00:00:00.000
19. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:52.165 Call Duration 00:00:00.000
20. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:52.366 Call Duration 00:00:00.000
21. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:52.567 Call Duration 00:00:00.000
22. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:52.768 Call Duration 00:00:00.000
23. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:52.969 Call Duration 00:00:00.000
24. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:53.171 Call Duration 00:00:00.000
25. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:53.371 Call Duration 00:00:00.000
26. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:53.573 Call Duration 00:00:00.000
27. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:53.774 Call Duration 00:00:00.000
28. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:53.974 Call Duration 00:00:00.000
29. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:54.176 Call Duration 00:00:00.000
30. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:54.377 Call Duration 00:00:00.000
31. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:54.578 Call Duration 00:00:00.000
32. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:54.779 Call Duration 00:00:00.000
33. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:54.979 Call Duration 00:00:00.000
34. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:55.180 Call Duration 00:00:00.000
35. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:55.381 Call Duration 00:00:00.000
36. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:55.583 Call Duration 00:00:00.000
37. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:55.783 Call Duration 00:00:00.000
38. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:55.984 Call Duration 00:00:00.000
39. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:56.185 Call Duration 00:00:00.000
40. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:56.386 Call Duration 00:00:00.000
41. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:56.587 Call Duration 00:00:00.000
42. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:56.787 Call Duration 00:00:00.000
43. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:56.988 Call Duration 00:00:00.000
44. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:57.189 Call Duration 00:00:00.000
45. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:57.389 Call Duration 00:00:00.000
46. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:57.590 Call Duration 00:00:00.000
47. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:57.791 Call Duration 00:00:00.000
48. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:57.992 Call Duration 00:00:00.000
49. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:58.192 Call Duration 00:00:00.000
50. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:58.393 Call Duration 00:00:00.000
51. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:58.594 Call Duration 00:00:00.000
52. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:58.795 Call Duration 00:00:00.000
53. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:58.995 Call Duration 00:00:00.000
54. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:59.196 Call Duration 00:00:00.000
55. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:59.397 Call Duration 00:00:00.000
56. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:59.598 Call Duration 00:00:00.000
57. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:59.798 Call Duration 00:00:00.000
58. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:11:59.999 Call Duration 00:00:00.000
59. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:12:00.200 Call Duration 00:00:00.000
60. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:12:00.401 Call Duration 00:00:00.000
61. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:12:00.601 Call Duration 00:00:00.000
62. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:12:00.803 Call Duration 00:00:00.000
63. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:12:01.003 Call Duration 00:00:00.000
64. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:12:01.204 Call Duration 00:00:00.000
65. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:12:01.405 Call Duration 00:00:00.000
66. viReadSTB (USB0::0x05E6::0x3706::01... (0x358DECD8), 0)
Start Time: 17:12:01.606 Call Duration 00:00:00.000
67. viWrite (USB0::0x05E6::0x3706::01... (0x358DECD8), ".localnode.prompts=0....", 115, 115)
Start Time: 17:12:01.807 Call Duration 00:00:00.000
68. viClose (USB0::0x05E6::0x3706::01... (0x358DECD8))
Start Time: 17:12:01.807 Call Duration 00:00:00.026
69. viClose (0x358E1520)
Start Time: 17:12:01.833 Call Duration 00:00:00.002
So my question is quite simple, what the hell am I doing wrong at this point?
Capture.zip
NI I/O Trace output
(2.22 KiB) Downloaded 994 times
