3706 & 3723 single-pole
zvikaef
Country: Israel
Post by zvikaef » May 24th, 2018, 12:58 am
hi
using the 3706 and the 3723 how can I change the 3723 to single-pole (120 channels) from: front panel, TSPexpress web app, program.
an example will help
thanks.
Vince W
Re: 3706 & 3723 single-pole
Post by Vince W » June 1st, 2018, 11:16 am
In the 3706A Reference Manual, Ch 2, p2-17...
(First select a range of channels - for example 3001:3120)
Press the CONFIG key and then the CHAN key to open the CHANNEL ATTR menu.
The CHAN ATTR menu contains:
LABEL: Sets the label associated with the specified channel. From the front panel, the label can be
up to 12 characters. Remotely, the label may be up to 19 characters. This option will not be displayed
if multiple channels are selected. Related command: channel.setlabel().
BACKPLANE: Opens the BACKPLANE menu. Use this menu to add or remove backplane channels
from the specified channels. Related command: channel.setbackplane().
FORBID: Allows or prevents the closing of the specified channels. Related commands:
channel.setforbidden() and channel.clearforbidden().
POLE: Sets the number of poles for the specified channels. Related command: channel.setpole().
DELAY: Sets additional delay time for the specified channels. Related command: channel.setdelay().
COUNT: Displays closure cycles for the specified channel. This option is not displayed if multiple
channels are selected. Related command: channel.getcount().
DMM-CONFIG: Sets the DMM configuration associated with the specified channels. Related
command: dmm.setconfig().
