3723 card failure.
sdkim1002
Country: South Korea
3723 card failure.
Post by sdkim1002 » October 10th, 2018, 10:32 pm
i used ODA EX600-3 P/S -> 600V 3A
use P/S Aging to LED(10ea Serial connection) in 2.5A CC mode at 400~500V
in Aging Test 3723 Channel is Open .
After Aging Test P/S is OFF and P/S cable is open to relay
After use 2400+3706+3723 Switch channel IV test.
3723 Card Fail in Aging Test. but Aging Test 3723 Relay is open.
I do not know why the 3723 card fail
Can I get a datasheet on the relays used for the 3723 card?
