Kickstart software with 3706A
Amith Kashyap
Post by Amith Kashyap » January 2nd, 2019, 12:59 am
Hello sir,
We are using keithley 3706A system switch/multimeter for resistance measurement and need to measure resistance values from 120 channels at a time.Is it possible in Keithley Kickstart software to measure resistance from 120 channels at a time?If not which software can we use with Keithley 3706A?
Thank you
Regards,
Amith Kashyap
Re: Kickstart software with 3706A
Post by Andrea C » January 2nd, 2019, 12:19 pm
You may find the KickStart software to be helpful for data logging from the 3706A. It has a trial license mode. I suggest you download and give it a try.
In your previous posts, you have indicated that you have the model 3723 switch card. This card will provide no more than 60 two-wire channels.
Amith Kashyap
Post by Amith Kashyap » January 2nd, 2019, 8:05 pm
Hello sir,
Thank you for the reply for my previous post.
But my question is about whether we can log the data from 120 channels at the same time using Kickstart software?
Thank you
Best regards,
Amith Kashyap
Amith Kashyap
Post by Amith Kashyap » January 8th, 2019, 7:02 am
Hello sir,
I am using Kickstart software trial version. Is there any way i can get a sampling rate of 1 sample/100 milliseconds in the software?
Thank you
Regards,
Amith Kashyap
Stuart M
Post by Stuart M » January 8th, 2019, 1:17 pm
We are using Keithley 3706A system switch/multimeter for resistance measurement and need to measure resistance values from 120 channels at a time.Is it possible in Keithley Kickstart software to measure resistance from 120 channels at a time?If not which software can we use with Keithley 3706A?
> Yes. KickStart Data Logger app channels are determined by the cards that are installed in the model 3706A.
> Yes. NPLC can be configured in KickStart Data Logger app Settings for each channel group.
Amith Kashyap
Post by Amith Kashyap » January 9th, 2019, 2:13 am
Hello sir,
Can you please explain me in detail how i can obtain a sampling rate of 1 sample/100 milliseconds/120 channels using keithley 3706(3723 card) for four wire measurement?
1)Do i need to adjust NPLC?If so what is the best NPLC setting?
2)Do i need to keep autozero,autorange,autodelay off?
I tried with different NPLC settings from 0.0005 to 10.0, I am getting around 112 samples/seconds irrespective of different NPLC settings.I am planning to buy the kickstart software if i know i can get the above measurement settings.It would be very helpful if you can help me with this.
Thank you
Regards,
Amith Kashyap
Raghu R
Post by Raghu R » January 9th, 2019, 7:57 pm
Hi Amith Kashyap,
I introduce as FAE for Keithely products here in India operating out of Banaglore.
My contact number is 9845046314.
Feel free to contact me or share your contact details for me to contact you.
Phone, e-mail id and Organization details.
Users browsing this forum: No registered users and 6 guests
