GetAllReadings command fails
iliosporos
Country: Greece
Post by iliosporos » May 13th, 2013, 6:05 am
Hello
I'm using 3706 Switch System and 3721 plug in card.
Systems firmware has been updated to 1.41. I'm communicating with the system via lan using c++ code.
I'm having troubles on reading the scanning results with the GetAllReadings command.
Everything is working fine when i'm taking just one measurement with Measure command but when i'm trying to get measurements using the multiplexing card i can't retrieve the scanning results. SAFEARRAY * IKe37XXMeasurementBufferReadingData::GetAllReadings fails resulting -2147192831 error.
There are 2 posts in the forum that are referring to a similar problem
1 http://forum.keithley.com/phpBB3/viewto ... 79c#p26488
2 http://forum.keithley.com/phpBB3/viewto ... 79c#p39987
but not any satisfactory solution to me.
Thanks in advance
Re: GetAllReadings command fails
Post by Andrea C » October 5th, 2015, 11:45 am
For LAN based connections and the GetAllReadings methods of the IVI driver, make sure that you have an LXI based connection rather than a socket based connection.
LXI: TCPIP::192.168.1.50::inst0::INSTR
SOCKET: TCPIP::192.168.1.50::5025::SOCKET
mouhoub06020
Country: France
Post by mouhoub06020 » December 6th, 2017, 1:55 am
i have the same issue awith the 3706A driver and i'm using the LXI to the adress ....driver.initialize is not working while the SOCKET is properly intializing the device !!
error of timout :( :(
mouhoub06020
Country: France
Post by mouhoub06020 » December 6th, 2017, 2:33 am
finaly working i had to connect to the driver using TSB before that i connect with my own application.
