Keithley 2300 Series Stability
BrianJCongdon
Post by BrianJCongdon » January 12th, 2015, 9:20 am
I am looking for a supply with extremely high stability/low drift. I need to source up to 1A and will never exceed 24V (I could go as low as 5V.) What do you suggest?
Re: Keithley 2300 Series Stability
Post by Dale C » January 12th, 2015, 10:56 am
I would suggest Model 2200-30-5.
This is a single channel power supply that can output up to 30V at 5A.
The specs are attached.
Series2200.pdf
(295.92 KiB) Downloaded 1047 times
BrianJCongdon
Post by BrianJCongdon » January 12th, 2015, 1:38 pm
I searched the 2200 series document and couldn't find a Stability or Drift spec. The data sheet for the 2300 series lists Stability as 0.01% + 0.5mV over an 8 hour period. Ideally, I'm looking for a supply that is more stable than the 2300 series; anything 5V or above will work.
Post by Dale C » January 12th, 2015, 1:46 pm
The Model 2300 series seems to be the only supplies that have stability and drift specs.
Even the SMUs(source measure units) do not have these specs.
BrianJCongdon
Post by BrianJCongdon » January 14th, 2015, 3:47 pm
Can you provide me with the Ripple and Noise specs for the 2300 series? The Specifications section of the downloadable instruction manual (Appendix A) is blank.
Post by Dale C » January 15th, 2015, 5:50 am
SPEC-2308 (A - Jul 2008)(Customer).pdf
(143.83 KiB) Downloaded 1069 times
2306RevA_DocSpec.pdf
(53.32 KiB) Downloaded 1065 times
2304AspecsrevA.pdf
(125.16 KiB) Downloaded 1046 times
2302RevA_DocSpec.pdf
(49.28 KiB) Downloaded 1046 times
BrianJCongdon
Post by BrianJCongdon » January 16th, 2015, 7:28 am
I'm specifically looking for the noise and ripple specs for DC Voltage output (Battery.) The only reference I can find to noise in the documentation is in the Pulse Current Measurement Operation section.
Post by Andrea C » January 16th, 2015, 8:59 am
The 2300 Series make use of a switching power supply to generate their output voltages and make use of an integrating A/D converter for the measurements.
I suggest you again consider one of the linear power supply products such as the 2200-32-3.
I've uploaded an application note on understanding the Linear Power Supply Specs including concepts of Stability from the provided temperature coefficient, load and line regulation and calibration interval information.
Ser2200LinPwrSuppySpecsAppNote.pdf
(620.16 KiB) Downloaded 1040 times
Return to “Series 2300”
