Hi
I need in my project to simulate a battery set with nominal voltage of 20V, and current limit of 2A, or 15V 3A is also an option. Is there any way to use your simulator devices for such apllication?
Regards
João Lourenço
Simulate battery of 20V 2A is possible?
- Keithley Applications
- Country: United States
Re: Simulate battery of 20V 2A is possible?
The 2304A can supply 20V at up to 5 amperes. Do you want to simulate battery capacity (amp-hours) as well? If so, then the 2460 may be what you want.
Ok, thanks for the reply. I'm not sure if i need the capacity, but i think it is not necessary. So i have been looking in datasheets of 2304A and a little confuse. This device can provide 100W (5A @ 20V)?
João Lourenço
João Lourenço
Yes 100 watts continuous 5A @ 20V as per the datasheet and specification document.
