Simulate battery of 20V 2A is possible?
2302, 2303, 2303-PJ, 2304, 2306, 2306-PJ, 2306-VS, 2308
jlourenco
Country: Portugal
Post by jlourenco » April 8th, 2015, 4:04 am
Hi
I need in my project to simulate a battery set with nominal voltage of 20V, and current limit of 2A, or 15V 3A is also an option. Is there any way to use your simulator devices for such apllication?
Regards
João Lourenço
brian.d.smith
Re: Simulate battery of 20V 2A is possible?
Post by brian.d.smith » April 8th, 2015, 5:54 am
The 2304A can supply 20V at up to 5 amperes. Do you want to simulate battery capacity (amp-hours) as well? If so, then the 2460 may be what you want.
jlourenco
Country: Portugal
Post by jlourenco » April 9th, 2015, 6:29 am
Ok, thanks for the reply. I'm not sure if i need the capacity, but i think it is not necessary. So i have been looking in datasheets of 2304A and a little confuse. This device can provide 100W (5A @ 20V)?
Thanks
João Lourenço
brian.d.smith
Post by brian.d.smith » April 10th, 2015, 4:57 am
Yes 100 watts continuous 5A @ 20V as per the datasheet and specification document.
Return to “Series 2300”
