2304A SCPI multiple query syntax broken
pigrew
Post by pigrew » November 9th, 2016, 11:49 am
I'm using a 2304A with firmware A02.
I'm having trouble performing multiple queries using one GPIB command. If I send the command, and read a reply too quickly, it will only return the first response.
For example, if I send "OUTP?;:VOLT?;:CURR:LIMIT?", I often will get the reply "0\n". If I add a delay between the write and read, then I'll get all three responses together (as expected), like ""0;0.000000E+00;2.500000E-01\n".
It looks like I have to only send one command at a time?
Would this be fixed in a later firmware release? If so, is it possible to update the ROM with a ROM programmer or are other hardware changes needed?
Re: 2304A SCPI multiple query syntax broken
Post by Andrea C » November 10th, 2016, 1:52 pm
As a work around, try using the *OPC to hold off the GPIB read until all pending commands are complete:
"OUTP?;:VOLT?;:CURR:LIMIT?:*OPC"
Return to “Series 2300”
