2306-VS - Leave Output On when using EXT Trigger
Derek M
Country: United Kingdom
Post by Derek M » October 2nd, 2012, 1:13 am
When using the External Trigger of the 2306-VS and carrying out a measurement (Current, Voltage, DVM), the output automatically switches off when exiting leaving Ext Trigger mode. If you want the output to stay on when leaving EXT Trigger mode, the following commands should be used:
TRIG1:EXT:STEP:VOLT:END xx This sets the desired output voltage when leaving Ext Trigger mode
TRIG1:EXT:SPER 1 '1' source persist = on. Default is '0' for off.
TRIG:EXT:ENAB OFF
Return to “Series 2300”
