2230 Output Voltage Polarity
Can the 2230-30-1 DC power supply outputs be set to a negative voltage? In other words can the + or - terminals be selectively grounded?
Re: 2230 Output Voltage Polarity
The Model 2230 power supplies cannot be set to negative voltage.
But the connections to the positive and negative terminals can be reversed by the user to obtain an negative voltage with respect to each other.
The positive terminal can be connected to ground to obtain a negative voltage with respect to ground.
